Setting the AIConvertClock rate in DAQmx .NET API
Hi!
I need to set the AI convert rate property of the DAQmx Timing class in my .NET application.
C API style works:
DAQmxSetAIConvRate(TaskHandle taskHandle, float64 data);
Labview works if I specify the active device:
 .NET API  has a property ->  "analogInputTask.Timing.AIConvertRate"
But if I set this property and run my application (cDaq-9188 Ethernet, NI9205 device), I get following exception:
"An exception of type 'NationalInstruments.DAQmx.DaqException' occurred:
DAQmx Timing property specified requires per device configuration.
Explicitly specify the device(s) to which this property should apply.
Property: NationalInstruments.DAQmx.Timing.AIConvertRate"
Cannot find an ActiveDevs property in the Timing class to use it like in Labview.
Any suggestions how to do this?
Best regards
Holger
(5,370 Views)
Hi Holger,
could you post the manipulation of the convert clock property in the context where you create the task and set the timin settings in .NET? I would like to take a look at this, if there is something missing. The exception sounds like that.
Melanie
Melanie Eisfeld
Senior Applications Engineer, National Instruments Germany
Certified LabVIEW Developer
Certified TestStand Architect
(5,353 Views)
Hi Melanie,
thanks for your help!
My code is splitted in too many small pieces, but essentially I do the same like the "AcqVoltageSamples_IntClk" from the examples:
  // Create a new task
  myTask = new Task();
  // Initialize local variables
  double sampleRate = Convert.ToDouble(rateNumeric.Value);
  double rangeMinimum = Convert.ToDouble(minimumValueNumeric.Value);
  double rangeMaximum = Convert.ToDouble(maximumValueNumeric.Value);
  int samplesPerChannel = Convert.ToInt32(samplesPerChannelNumeric.Value);
  // Create a channel
  myTask.AIChannels.CreateVoltageChannel(physicalChannelComboBox.Text, "",
                    (AITerminalConfiguration)(-1), rangeMinimum, rangeMaximum, AIVoltageUnits.Volts);
  // Configure timing specs
  myTask.Timing.ConfigureSampleClock("", sampleRate, SampleClockActiveEdge.Rising,
                    SampleQuantityMode.FiniteSamples, samplesPerChannel);
  // Verify the task
  myTask.Control(TaskAction.Verify);
  double convertRate = myTask.Timing.AIConvertRate
I`ve tested this example and the exception occurs in the last line.
Regards
Holger
(5,348 Views)
Accepted by topic author HoNeu
Hi Holger,
thank you for testing the example.
Could you try it with
myTask.Timing["cDAQ1Mod1"].AIConvertRate
instead of
? Replace the cDAQ description with the name of yours. You can look it up in MAX, if you are not sure what it is called.
Please let me know if this works for you.
Melanie
Melanie Eisfeld
(5,330 Views)
Thanks Melanie! This works!
I`ve never seen an example for using Timing like an array...
Best regards
Holger
(5,318 Views)
