I have been having a hardtime setting up an alarm that will also trigger a sound. Here is a pic of what im looking at.
When ever i try to just copy this for channels 1-15 nothing happens. BUT chan. zero still works (even thou i copy and paste)....is there a setting you need to change in order to work with more then one channel? Or is there a way i can get all 15 channels using that one Sound VI (VI name = 2). In other words, how can i tell lab veiw when, lets say 80, is passed by any of the chans. the sound will play.
Also, i need to be able to set the limit different on each channel.
