Shift registers and waveform graph for tare function - Strain readings
Hello users,
My goal is to reset a given strain back to zero when the strain has an initial reading. I guess that shift registers in combination with case structure will be used. I have attempted to use two waveform graphs -  one showing the offset strain and the other one showing the calibrated strain so it will be more clear to see the stabilised strain before the reset button is set to force the strain in the calibrated graph to start to zero. Is there any way to do it ?
Helen
(4,485 Views)
Cross-post in t5/LabVIEW
Cheers
(4,369 Views)
