Shunt Cal Select Property
I am trying to find more information about the
AI.Bridge.ShuntCal.Select Property.
There is an option to select switch A, B, or Switch A and B
What switches are these refering to?  I thought there was a shunt calibration switch for each channel the connects to a 10K resistor?
I am using the NI 9237 Strain module with the CDAQ chasis.
Could someone please elaborate.
Dan
Dan Shangraw, P.E.
(3,242 Views)
Hi ASTDan,
The switches that you are referring to are for the SCXI 1520, where page 38 of the user manual explains them https://www.ni.com/docs/en-US/bundle/372583e/resource/372583e.pdf
Take a look at DAQmxPerformStrainShuntCal and DAQmxPerformBridgeShuntCal for the 9237.DAQmxPerformStrainShuntCal
h_baker
(3,224 Views)
