Signal generation of A1*sin(w1t) + A2*sin(w2t)
Dear Sir,
Could you teach me how I can generate the combination of two sine waves: A1*sin(w1t) + A2*sin(w2t) ?
Thank you.
Soobum Lee
(5,004 Views)
Hi Soobum,
Provided you are using LabVIEW, I would use the Multitone Generator.vi:
 LocationMultiToneDesc
This will take an array of the frequencies, amplitudes, and phases that you want to use and can easily be scaled to include more than two sine waves.  Let me know if you have any questions, thanks for posting!
-John
Message Edited by John P on 11-07-2008 10:08 AM
Message Edited by John P on 11-07-2008 10:09 AM
John Passiak
(4,992 Views)
I found multitone generator and tried as shown.
All I need to set is the amplitudes and the frequencies of two sine waves.
But when I run this it gives an error message saying:
Error-20002 occurred at "NI_MAPro.lvlib:m_MultitoneParamsCheck.vi" when called from "NI_MAPro.lvlib:Multitone Generator.vi:3"
Possible reason(s):
Analysis: The input sequences must be the same size.
How can I resolve this?
Thank you.
Soobum Lee
(4,963 Views)
You have provided only two input arrays with 2 elements and are letting the tone phases input be the default. The default has 4 elements in the array so there is a mismatch.
(4,952 Views)
I added two more element for amplitude and frequency and it works. Thank you.
(4,940 Views)
Another option would be to wire the phase input with a constant array of zeroes.  The array should be the same size as your other two inputs to avoid the error you initially received.
-John
John Passiak
(4,931 Views)
