Simple Oscilloscope with BNC-2110?
Hi all,
We're trying to set up a simple oscilloscope using a NI BNC-2110 board and LabView 2013 (SP1). I'm a complete beginner to this software and have only rudimentary knowledge and use of it.
All the best,
Sam Naughton
(3,988 Views)
The BNC-2110 is nothing more than a connector block.  You need a DAQ board that can do the measurements for you.  Depending on what you need to measure, you can probably get away with a simple USB-6000.  From there, look through the Example Finder in LabVIEW (Help->Find Examples).  There are a few in there for Analog Input.
GCentral
(3,982 Views)
