Simulate arbitrary waveform analog output
Can the Simulate Arbitrary Waveform Express VI be used to output analog signals to physical channels on analog output systems such as the NI 9263? I am trying to use the arbitrary waveform generator VI to output a signal used to drive magnetic coils.
(3,813 Views)
Accepted by topic author Zach_Phys_Research
Why don't you just try it and see what happens?  As far as I know, it should work.
(3,805 Views)
