Simulate vibration signal
Hi, im quite new to LabView.
Im having trouble finding the best way to simulate aacceleration response from a vibration event.
figure 1 is the signal i want to simulate
figure 2 is what the part of the signal i want to extract to then analyse
any help would be great
thanks
richard
(4,010 Views)
I don't really understand what you what to simulate?
The output signal?  Take the one you sampled and replay ?
If you have a model of your system you can usse the math/ode vis to simulate it.
And remember: Usually accelerometers are also mechanical systems ( a one-degree-of freedom-system in it's simplest form)
Greetings from Germany
Henrik
LV since v3.1
(3,973 Views)
Yes I want to simulate this output signal,
I want to create a vibration 'event' similar to an impact, all I can seem to do is create constant waveforms which is not what I need
(3,967 Views)
