Simultaneous operation of AI and DO
In my application I am using a AI and DO of a DAQ card. I want AI and DO operation in indpendent loops(parallel operation). Is it possible to achieve this? Do you have some sample vi's for the same.
Regards
Gopal
(3,411 Views)
Yes, this is possible
I do not have any example vi's at hand to demonstrate this
but probably, you can choose a continous Analog measurement vi and Digital generation vi that you will find in example vi's shipped with LabVIEW, merge these to a single vi and achieve this
(3,395 Views)
Hi Gopal,
Thank you for posting to the NI forums.  Which DAQ device and driver are you using for this application?  Also, could you give some more general background on the reasoning behind using two independent while loops rather than a single loop?  Keep in mind that if you want the AI and DO synchronized, they won’t hardware timed due to the separate while loops.
With some more information, I’d be glad to offer some recommendations or even a sample VI.  Thanks!
Ed W.
(3,378 Views)
In my application, I need to constantly monitor a voltage signal on my AI. I could do this sequentially, but I prefered to have the DIO operation independent of the AI. Thus I planned to use two loops where in have my voltage monitoring in one and the DIO operation on the other.
Regards
Gopal
(3,327 Views)
Hi Gopal,
Again, it would be very helpful to know which DAQ device and driver you are using.  I would recommend getting started using the LabVIEW Example Finder.  I’ve attached a sample program – it simply consists of two LabVIEW example programs placed into a single VI.  But keep in mind that these two loops are not synchronized at the hardware level.
Ed W.
(3,309 Views)
