Slight changes needed in vi for compatability with 9219
Basically, I am a medical scientist with no background in computers or electronics and I have been given to .vi files which are used to measure and record small changes in voltage from a strain gauage and plot them as force (in dynes) against time. The problem is that these files were written years ago for use with a PCI 6024E and have a 9219. I have attached the files that I am using ( "single-channel2.vi" is the main vi and it will ask for "Max_Write_To_Spreadsheet_File.vi", "Max4_Input_Analogue_Single_Point.VI" and "Card_Setup.vi"). When I try to use this vi with my 9219 there are no readings, presumably because "Card_Setup.vi" is for the PCI 6024E. I have tried myself to replace "Card_Setup.vi" with my own .vi for the 9219 (see attached file "9219.vi") using the DAQ wizard but I don't know how to connect it to the main vi and even if I have set it up correctly. If anyone has the time to have a look at the set up and see how 9219.vi should be set up to be compatible with the rest of the vi it would be greatly appreciated. Incase it helps, the voltages being measured are between -4 and +4.
thanks,
Jamie
P.S as only 3 attachments can be added, some have been added to the subsequent post.
(2,819 Views)
(2,818 Views)
(2,809 Views)
