Specified operation cannot be performed while the task is running. Task Name: ClockTriggerBit
I am trying to set the timing for digital line on 6221. As recommended in the documentation "NI DAQ MX C reference guide" I stop the task, run the following:
DAQmxCfgOutputBuffer
DAQmxCfgSampClkTiming (taskHandle, "ao/SampleClock", 100, DAQmx_Val_Rising, DAQmx_Val_FiniteSamps, 10);
DAQmxWriteDigitalLines
DAQmxStartTask -> this is when I get the warning 4294766817. Why?
Any better way to set the sample clock? I need to do it using internal clock in 6221.
Thank You,
Mark.
(5,195 Views)
Did you try starting the task before writing?
John Weeks
WaveMetrics, Inc.
Phone (503) 620-3001
Fax (503) 620-6754
www.wavemetrics.com
(5,194 Views)
Oh yes - with another error/warning telling me not to. Also in an example code that is the sequence - stop, set up, write, start.
Mark
(5,190 Views)
Huh. I guess we need input from someone more knowledgeable. Sorry.
John Weeks
WaveMetrics, Inc.
Fax (503) 620-6754
www.wavemetrics.com
(5,186 Views)
Hello Metrikos,
I've got a couple things.  First, could you be more specific as to where in the DAQmx C Reference Help you are referring to.  Secondly, attached is an example of corellated digital input with analog input.  I know this isn't exactly what you are trying to do, but it might give you a good reference.
-Alan A.
(5,174 Views)
Thank You Alan,
I've been away for a few days and could not try your code. I'll try it as soon as I can, but already see the potential solution to my problem - I need to use analog clock, as it seems there is no internal clock for digital.
As far as your question - I am not sure an realy do not want to go searching. It was either a line in help or something a warning text said.
Again, thank You!Insert Smilies
Mark
(5,163 Views)
That's correct.  I should have mentioned this before, but there is no dedicated digital timing engine on M Series devices.  So to perform timed digital operations, you have to use another clock source, like analog in or out, a counter, or an external source.
-Alan A.
(5,151 Views)
