Specifying timing device with cDAQ 9178 and NI 9201 module in python
Hello.  I am trying to perform a delayed analog input measurement using a cDAQ 9178 and NI-9201 analog input module.  I am tryiung to port code running on an NI-4363 but am running into an error:
det_task.ai_channels.add_ai_voltage_chan(self.detector_channel)
det_task.timing.cfg_samp_clk_timing(rate=ACQ_RATE, source = 'PFI1',
                                                            samps_per_chan=samples,
                                                            active_edge=Edge.FALLING)
det_task.timing.delay_from_samp_clk_delay = peak_delay
When I run this, I get the following error on the last line:
inidaqmx.errors.DaqError: DAQmx Timing property specified requires per device configuration. Explicitly specify the device(s) to which this property should apply. Property: DAQmx_DelayFromSampClk_Delay
It seems pretty clear that I need to set the active device, but I have no idea how to do this.  I found this thread (https://forums.ni.com/t5/Multifunction-DAQ/DAQmx-Timing-property-specified-requires-per-device/td-p/...) where it looks like it can be done in LabView, but I'm not really sure how to do it in python.  Any suggestions on how to set this in python?
Message 1 of 1
(1,016 Views)
