Spliting up NI-DAQmx functions gives me error code -200088
I took one of the example C files and started to split up the functionality so I can call upon them in a larger program.
When I do this, when the second function works with TaskHandle, I get error -200088.
I set the TaskHandle variable as a global and during debug, I see that the value has not changed when it hits the second function.  Why has the handle become invalid??  I cut and pasted the section of code below.
I saw a simlar problem in the following post, but there was no answer...
http://forums.ni.com/ni/board/message?board.id=250&requireLogin=False&thread.id=16497
Thanks in Advance!
Running on Visual C++ 2008.
 int DAQ_fnInit(void) {
    // DAQmx Configure Code
    DAQmxErrChk (DAQmxCreateTask("",&DAQ_taskHandle));
    DAQmxErrChk (DAQmxCreateAIVoltageChan(DAQ_taskHandle,CHANNELS,"",DAQmx_Val_RSE,MINVOLTAGE,MAXVOLTAGE,DAQmx_Val_Volts,NULL));
    DAQmxErrChk (DAQmxCfgSampClkTiming(DAQ_taskHandle,"",SAMPLERATEHZ,DAQmx_Val_Rising,DAQmx_Val_ContSamps,SAMPPERCHANTOACQ));
    //Configure the DAQ so that the buffer is overwriten.
    DAQmxErrChk (DAQmxResetReadOverWrite(DAQ_taskHandle));
    DAQmxErrChk (DAQmxSetReadOverWrite(DAQ_taskHandle,DAQmx_Val_OverwriteUnreadSamps));
    DAQmxErrChk (DAQmxSetReadRelativeTo(DAQ_taskHandle, DAQmx_Val_MostRecentSamp));
    DAQmxErrChk (DAQmxSetReadOffset(DAQ_taskHandle, 0));
    DAQmxErrChk (DAQmxStartTask(DAQ_taskHandle));
    Error:
    DAQ_fnCheckError();
    return NI_error;
void DAQ_GetMeasurement(void) {
    int32       NI_qtyofreadpts;
    float64     NI_data[200];
    //Battery Calculation
    DAQmxErrChk (DAQmxReadAnalogF64(DAQ_taskHandle,100,DAQmx_Val_WaitInfinitely,DAQmx_Val_GroupByChannel,NI_data,200,&NI_qtyofreadpts,NULL));
    Error:
    DAQ_fnCheckError();
void main() {
    DAQ_fnInit();
    DAQ_GetMeasurement();
    printf("End of program, press Enter key to quit\n");
    getchar();
(3,384 Views)
Yesterday, I ran across a very similar problem, and I also figured that there must be something wrong with the task handle - but it wasn't. I resolved my problem by changing in the call to DAQmxCfgSampClkTiming() the parameter DAQmx_Val_ContSamps to DAQmx_Val_FiniteSamps.
I do not know how this could make the difference, though, in my application I do need only a definite number of samples and changing the parameter seems to make sense for this reason. Only, I needed to make sure, that my reading routine does not read beyound the defined number of samples.
Best regards
Rolf
(3,364 Views)
