Square wave from USB6009?
How can I get a square wave with variable duty cycle from USB6009 DAQ. Should I use the analog output or the +5v output can also be modified.
Thanking in advance
(3,412 Views)
Use either the analog output or digital output. You will do a single point DAQmx Write, Delay, single point DAQmx Write, delay. As you are probably aware, the 6009 only supports software timed output so the timing will be subject to quite a bit of jitter and the  frequency is probably not going to exceed about 150 Hz.
(3,401 Views)
