Starting stacked structure
I am working on a project to create the dashboard of a car.I have a stacked structure with a few frames. I want to have an ignition boolean control that will start and stop the stacked sequence once i have already hit run continuously. Any help would be greatly appreciated.
(3,286 Views)
Also is there any way to change the frame numbers to frame names? For example, Engine, radio, etc.
(3,284 Views)
1. Your question has nothing to do with DAQ.  It would have been better to post to the LabVIEW Board.
2. Run continuously should never be used to operate a program.  It is for very limited use in testing during program development. You should wrap you code in a while loop and add a Stop boolean on the front panel to allow the user to stop the program.
3. Stacked sequences have no place in a modern LabVIEW program. They were useful in the very early days. Replace with a case structure. If you pop up on the border of the frame, choose Replace >> Replace with Case Strucure from the pop up menu.
4. Frames only have numbers.
Now, the solution to all your problems in one easy (well, not too difficult) step: Convert your program to a state machine.
A state machine is implemented as a while loop (item 2 above) containing a case structure (item 3) with a state variable passed from one iteration to another via a shift register.  If you use an enumerated type (enum) the item names of the enum show up automatically as the case names. By ameking the enum a typedef you automatically have any changes propagate through all the cases and averywhere a copy of it is used.
There are examples of state machines which come with LV and many more on the Forum.
Lynn
(3,276 Views)
