Stop acquisition and generation with a case structure
Can you clarify whats prompting the program to stop, prior to completing the for loop iterations?
regards,
Glenn
Glenn
Message 11 of 13
(934 Views)
It's a comparison. In the "for" Loop, each data point is compared to a reference value. If an acquired data is less than that threshold, the "for" Loop stops. The whole computation stops to run too but with a delay.
Message 12 of 13
(932 Views)
Move the append waveform outside the For Loop.  Also, you can probably replace the For Loop with a while loop since it appears the number of iterations isn't too important.
Glenn
Glenn
Message 13 of 13
(914 Views)
