StopTask hangs for a few minutes
I use NIDAQmx under VS2007 C++.
I have problem with stopping task.
DAQmxStopTask return after 5-10 minutes. It depend on CPU. CPU usage is 100%.
There is no READ/WRITE operation in the same time.
Could this be caused by calling StopTask in calback registered by DAQmxRegisterDoneEvent?
Thanks for help.
(3,242 Views)
Fizyq,
Are you using loops in your application?
How do you have your acquisition configured? Number of samples, sample rate, etc..
Have you always observed this behavior?
Can you use a shipping example that came with DAQmx and get the same outcome?
The examples are located at:  C:\Documents and Settings\All Users\Documents\National Instruments\NI-DAQ\Examples
Ryan N
Application Engineer
ni.com/support
(3,224 Views)
Yes. In EveryNSampleEvent callback I read inputs until ther is no more samples.
I have two callbacks gegistered by
 1. DAQmxRegisterEveryNSampleEvents
 2. DAQmxRegisterDoneEvent
In 1. I read inputs, when error ocures I StopTask
In 2. I StopTask
I have continous aqusition with 25kS/s/ch (4 AI from NI 9233 and 2 AI from  NI 9205)
Yes. On Intel Celeron 600MHz it stops for 9-11 minutes, on Pentium 4 1.6GHz it stops for about 5 minutes.
I StopTask only after some errors - I turn off /turn on power suply or I pull out/insert USB communication cable.
I will check the example you mentioned.
(3,202 Views)
Fizyq,
It sounds like something in your code is causing a hang.  If you can post back your results from one of the example programs installed on your machine, which will help in determining the source of the issue.
Also, when you do post your results can you post your code that is causing the issue; this will also help in troubleshooting.
Thanks!
Ryan N
ni.com/support
(3,185 Views)
