Strain gauge set-up with NI 9237
Hi all,
I require a bit of help with my strain gauge application. I am measuring torsion on solid circular bars and will be using a half bridge set up with two active gauges to aquire my data. I will be using NI9237 and plan to connect up my gauges to this via NI9949 screw terminal adaptors but I am unsure of what wires to connect up to each pin. Also if there is anything else that you think might help please let me know!
Thanks in advance,
Andy
(6,009 Views)
Hi Andy,
Use the Connection Diagram tool to view the required signal connections between your sensor and connector block. You can view this by placing a DAQ assistant, configuring it for a strain measurement using your 9237, then clicking on the "Connection Diagram" tab.
You'll get something like this:
(5,966 Views)
(5,965 Views)
Thanks for the help guys. I have worked it out now! Another thing, is it necessary to connect up Shunt Calibration with Remote sensing as well? The NI9237 manual says only AL+ EX+ EX- RS+ and RS- are required for half bridge but the diagram includes SC connections as well.
Thanks again!
Andy
(5,930 Views)
