Strain gauge
I have a PCI-6224, SC-2345, 2 cables, 2 SCC-SG01 quarterbrige strain gaue modules.
Win XP Max 3.1, Nidaq 3.0
I am using the first set of channels 0-15 , to read analog voltage data (connected thru SCB 68 to terminal 1 of PCI-6224). The SG01 modules are put in SC-2345 slot J1 and J2. I configured the SC-2345 thru Max. The SC-2345 is connected to the 6224 daq card thru terminal 2.
I used daq assistant to generate a typical vi to read strain gauges.
question,1
how does daq assistant know that the SC-2345 is connected to terminal 2 and not 1. that is , the analog strain gauge channels read are 16,24, 17,25, as opposed to 0,8, 1,9 ? Currently, it uses syntax like SCC1/Mod1/ai0 etc
question 2,
Instead of worrying about configuration and all of that, and SCC1/Mod1/ai0 and all of that, can I simply treat the SG modules as simply output modules, that is
configure all my analog input channels as NRSE (range -10 to +10 V)
then read my analog voltage data, read all the channels that I need, including the SG01 channels (as dev1/ai16,dev1/ai24,dev1/ai17,dev1,ai25
and, then for the SG voltage data, I divide by 100 (because the SG modules have a gain of 100)
then use the calculated (divided) voltage as input to a the "convert strain gauge reading.vi", and calculate the strain (assuming my input data is set properly ; excitation voltage, bridige configuration, etc...
(3,379 Views)
1) The pins match up between both connectors. That is, the analog input pins are the same on both terminals. The only difference is if it is AI 0-15 (Connector 0) or AI 16-32 (Connector 1). The AI0 on the end of the SCC1/Mod1/ai0 refers to the connector on the SC 2345 not the actual connector you are using. This is because the M Series boards are the first devices to have multiple connectors, so this was not an issue in the past. So, even though you are using Connector 1 (AI 16-32) the device string will still be SCC1/Mod1/ai0:15.
2) You can definitely use Dev1/aiXX as your string to call particular channels on the SC 2345. That is, if you are using Connector 0, then you will be using AI 0-15. For Connector 1, you will obviously be using AI16-32. You are also correct in that you will have to do the scaling in software as you mentioned.
I hope this helps. Have a Great Day!
George
(3,361 Views)
This is what NI support said about recognizing bothe terminals (connectors of the M series Card)
"To answer your question:
1. How does NI-DAQ know that the SC-2345 is connected to terminal 1 or 2?
That is indeed a very good question. From M-Series (PCI-6224 is part of
it), you can connect two SC-2345 to one M-Series DAQ board. However, it's
going to be supported from NI-DAQ 7.4 which is going to be released soon.
Therefore, at this moment, you should connect SC-2345 to the terminal 0 of
the PCI-6224 board in order not to lose some of the functionality (ex.
counter/timer or analog output) of DAQ board even though it works fine for
analog input. There is a relative KB. Even if it's about E-Series board,
it'll be same for M-Series before NI-DAQ 7.4. Please refer to the below
link for more information.
http://digital.ni.com/public.nsf/websearch/5000D181F76162FF86256A3B00562560?OpenDocument
So, it is going to be supported in Nidaq 7.4. Just to share the info.
(3,345 Views)
