Sugestion for replacing DAQCard-6062e
I have a DAQCard-6062e and I want to replace it with a new card with PCI Express (PCIe) port, We want the same specifications as the old one. What kind of card do you suggust?
Message 1 of 8
(5,011 Views)
Did you see the recommendation for the 6351 on the 6062 product page? It has a PCIe version.
Message 2 of 8
(5,004 Views)
Accepted by topic author vahhab
Message 3 of 8
(4,998 Views)
That's the one.
You do know that a simple call to your local sales engineer would be the best thing you could do.
Message 4 of 8
(4,994 Views)
Okk, For sure I will also call them. Thank you.
Message 5 of 8
(4,989 Views)
It's not very polite to mark your response as the solution.
Message 6 of 8
(4,985 Views)
Hello all,
Due to some problems, our team leader decided to use the old DAQ (DAQCard-6062e) card on the new PC. Now I encountered new problems :), I have windows 7 (32 bits) and I installed Labview 14 with DAQmx and also Traditional DAQ 7.5 because our program is too big and written with the old Labview version and rewriting the program is time consuming and we do not have time.
When I run the program, I receive error 10243 and after that error 10401. I could not reset the driver in the "Measurement and Automation Explorer" because "right click" is disabled!  I uninstalled the DAQmx and continue working with T DAQ (To solve error 10243) but still have the same problems. As I understood the version of the labview does not match with the old driver and I have to use lower versions. Is it right?
Another question, can be both drivers (DAQmx and T DAQ) exists on one PC to run the devises?
Best,
Message 7 of 8
(4,833 Views)
@vahhab wrote:
Hello all,
Best,
Tell you team leader to look at https://www.ni.com/en/support/documentation/compatibility/16/ni-daqmx-and-labview-compatibility.html and
https://www.ni.com/en/support/documentation/compatibility/22/traditional-ni-daq--legacy--windows-vis...
Tell him also that tIme wasted = as money wasted.
Message 8 of 8
(4,829 Views)
