Swapped chip on USB-6008 question
I have an USB-6008 Daq that went bad in a set-up.  The MCU was getting very hot when plugged in (I had a ground problem that fried it).  I ordered a new MCU and replaced it, now it does not get hot at all when plugged in but I need to flash it I think.  The does not do anything, the led does not flash and the computer does not even acknowledge it has a device connected whether it recognizes it or not.
Has anyone here done a repair like this?
Where can I get the software to flash the chip and can it be done at my site?
Thanks all,
(3,481 Views)
Accepted by topic author ChillyWilly
Hi ChillyWilly,
You should contact the Customer Service department and look into returning the device.  If it is within 30 days of purchase, then this should not be an issue and would be significantly easier than attempting to flash the device yourself.  You will need the device serial number when you call.  Hopefully this helps!
h_baker
(3,444 Views)
I contacted Support earlier today and they do not have a solution.
I did not RMA the part because it was damaged by us as we used it in a non-conventional way and was definitely out of the 30 day warranty.  The MCU was very inexpensive and replacing it was fun and gave me some more experience with electronics.  At this point there is nothing to do and all that was gained was experience in removing and replacing surface mount parts of small pin pitch.
(3,440 Views)
If you decide to pursue a career in the field...
https://careers.peopleclick.com/careerscp/client_nationalinstruments/external/jobDetails.do?function...
(3,406 Views)
