Sweep voltage range with trigger
Hi everyone,
I have an application where I have a source in my setup which is generating TTL trigger pulses at a rate of roughly 15 per second. The pulses are 16us long and 3.3V.
I want to program my USB-6343 so that one of the analog output channels will step through a list of 100 voltages when each pulse comes in. When the list is finished the output value no longer changes (though pulses may still be generated in the setup).
I am using pyDAQmx if that matters at all.
Thank you for any help you can give!
(1,399 Views)
I'm no help at all on the Python syntax, but the idea will be:
1. Configure a task where timing is set for Finite Sampling and 100 samples.
2. Further configure it to use the source pulses as an external *sample clock* signal, rather than thinking of them as "triggers."
-Kevin P
(1,355 Views)
