Switch Relay Control Deprecated? How to use NiSwitch to control more than 1 Relay?
How do we control more than one relay at the time (PXI-2569) using niSwitch?
The former relay control from DAQmx that opened multiple relays is now considered as deprecated.
Thank
(4,070 Views)
Can we switch all relays in a loop without a timer or each relay must be within the Maximum Cycle Speed?
Ex: 2569 has a 145cycles/s, does that mean that I need to flip each individual with a delay of 7ms between each relay?
(4,049 Views)
Hi Foreshadow20,
This other forum post looks like it has your answer:
http://forums.ni.com/t5/Switch-Hardware-and-Software/Get-relay-position-multiple-with-NI-Switch/td-p...
Cheers,
Hannah Zimmerman
(4,027 Views)
