Synchronisation loss between labview and DAQ
Hello all
I am developing a labview code that generates a wave output with the NI cDAQ-9189 and module NI9269. From time to time I loose the synchronization to the chassis and I get a synchronization error when I want to read out the sampling rate through a property node(DAQmx Timing: Sampclk.Rate). Generally, the code works on my computer and my setup and I am able to develop and operate the module through labview. However, I need to re-plug the Ethernet cable from time to time to switch between internet access and chassis connection.
The following steps give the following results:
- resetting the DAQ -->  doesn't solve the issue
- restarting labwiew --> doesn't solve the issue
- restarting the computer --> solves the issue
- operating the module through NI-max works.
Used example: Voltage (non-regeneration) - Continious Output.vi
Node that generates the error:: DAQmx Timing: Sampclk.Rate
Labview: 2020
NImax Device Driver: 20.7
Chassis: NI cDAQ-9189
IO Module: NI 9269
I do not want to restart my computer everytime to just eliminate an error like this. Does anybody know what the issue could be?
Thank you in advance!
(1,425 Views)
Try Error -209836 in DAQmx Start Task on TSN-Enabled cRIO or cDAQ
https://tmesystems.net/
(1,391 Views)
Thank you for the answer. We tried already that error case, but the error appears before starting any task but right after setting the sample clock.
(1,338 Views)
