Synchronization Techniques for Data Acquisition
here's my configuration :
-Board is a PCI 6052E
-IDE is Visual C++
-I'm using the NIDAQ API
I'm having trouble synchronizing a data acquisition sequence on the start of a waveform generation.
I tried the following instruction sequence :
Select_Signal(deviceNumber, ND_PFI_5, ND_OUT_UPDATE, ND_HIGH_TO_LOW);
Select_Signal(deviceNumber, ND_IN_CONVERT, ND_PFI_5, ND_HIGH_TO_LOW);
But it's still about 90ms late. So I have a few questions:
Does the acquisition has to be configured with an internal or external trigger when using this method? When I set trigger to external the acquisition holds on indefinetly.
Do the above instructions internaly ties the timing signals together or do I have to make a
physical link on the connector?
Does the acquisition has to be launched prior to the generation? The result is the same weither I launch it before or after.
Any idea of what I did wrong? A little help would be greatly appreciated.
Lotfi
(2,769 Views)
Ok boys forget it I found the answer on my own.
In case somebody encounter the same problem I give the answer:
-The data acquisition must be configured with an external trigger
-The timing signal used to command the start of acquisition should be ND_IN_START_TRIGGER instead of ND_IN_CONVERT
here...
Select_Signal(deviceNumber, ND_IN_START_TRIGGER, ND_PFI_5, ND_HIGH_TO_LOW);
triggerType=1 /*external*/
DAQ_Config(deviceNumber,triggerType,0);
(2,769 Views)
