Synchronization with external board
I did some further research. Seems like you can only route the start trigger and sample clock using the DIO module. If you want the entire cDAQ chassis to use an external timebase, you need to use NI-9469.
See Multi-chassis Tasks section in Signal-based Synchronization of Analog Input C Series Modules with NI-DAQmx in LabVIEW
https://tmesystems.net/
Message 11 of 14
(835 Views)
I do not understand. Why would I need the NI-9469 if I have only one chassis?
I think that your first idea is sound, can I ask you why it should not work ?
Message 12 of 14
(833 Views)
Technically, you are using more than a cDAQ chassis, one cDAQ + external board.
Using the sample clock synchronization, you are limited to only one sampling rate. If you want to run multiple modules at different sampling rates, you need to synchronize the clock at a lower level, at the timebase level. See the following figure for the derivation of different clocks.
Reference: Clocks
Message 13 of 14
(814 Views)
Thank you again for your answer and sorry for the late reply.
Ok, it makes sense. I am going to read some more documentation and get back here as soon as I have a better understanding.
Thank you again
Message 14 of 14
(780 Views)
