Synchronizing 3 different card types:S serie, M Serie and DynamicSignalAcquisition in C
Trying to synchronize a M, a S and a DynamicSignalAcquisition using Daqmx and reference clocks.
Here is how I set reference clocks
M:
DAQmxSetRefClkSrc(t_TaskHandle, "PXI_Clk10")
DAQmxSetRefClkRate(t_TaskHandle, 1000000) // 10 MegaHtz = 10 ^ 6 (aka 6 zeros)
S:
DAQmxGetMasterTimebaseSrc(t_TaskHandle, "/Dev1/20MHz", PXI_BufferSize));
FAILS -> DAQmxSetMasterTimebaseRate(t_TaskHandle, MHTZ10));
DynamicSignalAcquisition:
FAILS -> DAQmxSetRefClkRate(t_TaskHandle, 1000000) // 10 MegaHtz = 10 ^ 6 (aka 6 zeros)
Now how am I suppose to use the same clocks if I can't use PXI_Clk10 for the S and got no SetRefClkRate for the DynamicSignalAcquisition...
Please tell me how you usualy do it,
Seb
Message Edited by Sebastien Dupere on 10-28-2009 11:21 AM
(3,899 Views)
Hi Sebastien,
DSA devices over sample, and hence there sample clocks are not the same as a normal DAQ sample clock, usually this means the DSA card has be used as the master and will not accept an external time base. The following KnowledgeBase article talks about it more.
Synchronizing Dynamic Signal Acquisition (DSA) Products with NI-DAQmx
Synchronizing DSA or S Series Devices With a Single NI-DAQmx Task
I hope that helps,
Scott M.
(3,877 Views)
One consideration scare me:
General Rules and Conditions:
        All Devices
    • All channels in the task must be analog input channels of the same type of device (all DSA devices, or all S Series devices)
    • I want S and DSA together
  •  Also: I am able to time M series on the CLK10 and DSA on the CLK10...does that mean M are compatible with DSA and only S is not?
(3,866 Views)
Hi Sebastien,
I found the following paragraph in the S Series Manual:
Some S series cards can import external clocks, however they have to be on RTSI (PXI_TRIG) 7. You can see more on this in the S Series Manual, chapter 10 (pg 89) discuses sharing time bases.
Hope that helps.
Scott M.
(3,839 Views)
Tried to call
char t_RefTimebase[PXI_BufferSize]; MACRO_DAQmxErrRep(DAQmxGetMasterTimebaseSrc(t_MasterHandle, t_RefTimebase, PXI_BufferSize)); MACRO_DAQmxErrRep(DAQmxConnectTerms(t_RefTimebase, NISYNC_VAL_RTSI7, DAQmx_Val_DoNotInvertPolarity)); MACRO_DAQmxErrRep(DAQmxSetMasterTimebaseSrc(t_TaskHandle, t_SlaveSerieSRefClockName));
And it gave me:
Property not supported: MasterTimebaseSrc for my PXI-6143
Am I using the wrong call? thought the master timebase was what I needed to route on the RTSI7
Message Edited by Sebastien Dupere on 11-03-2009 08:13 AM
Message Edited by Sebastien Dupere on 11-03-2009 08:15 AM
(3,831 Views)
