Synchronous AI in warp mode
Hi!
I am using a PCI 6120 under LabVIEW 8.2, my DAQmx-Driver-Version is 9.1.1, I have saved the warp_mode.dll from LabVIEW11 for 8.2 and it works correctly.
I want to know, if and how I can handle multiple AI and AO in warp mode.
(What I need to do is, handling one AO (voltage) and two AI (also voltage) under warp mode.)
I have two problems:
1) the output starts way earlier than the input (obviously...) and exporting the AI/StartTrigger just won't solve my problem, because I still need to configure and start my counter for implicit timing
2) can two AI work with the same counter as timebase if I use implicit timing?
Greetings and thanks in advance for the help,
Eliza
(3,823 Views)
The delay is by the way almost exactly 1.5 milli seconds.
(3,822 Views)
I just realised, the uploaded pdf has terrible quality. as i can't chance the first post anymore, here's the one with better resolution:
(3,780 Views)
if i put it in the wrong sub-forum, please tell me.
(3,646 Views)
Hi Eliza,
I think this community poast treats solve your problem. below this post you find an example VI.
On the page of NI you find two further introduction how to use warp mode on special hardware:
http://zone.ni.com/devzone/cda/epd/p/id/3987 and
http://digital.ni.com/public.nsf/allkb/E09547F960143EF08625724400353D19?OpenDocument
Does this help you?
Philipp
(3,562 Views)
