Syncronise continuous analog with analog aquasition
Hi I am trying to create a psuedo Vector Network Anaylser from a PCI-6110 DAQ card.  I am using one analog output to generate a continuous sine wave then detecting the amplitude and phase of the received signal on one of the analog inputs.  I am then sweeping this process across frequency to simulate a VNA.
My problem is that I need to syncronise the detection with the phase of the generated sine wave so I can measure the phase change correctly.  I can do this if I generate finite samples and trigger the acquasition from the "ao/SampleClock" but then I start acquiring from the very begining of the signal.  What I really need to do is start acquasition on the Nth cycle of the generated waveform.
(3,340 Views)
You can specify a delay to get the acquisition to wait for a specified amount of time after recieving a trigger before it actually starts. You do this by setting the Start >> More >> Delay trigger property. What development environment are you using (LabVIEW, CVI, VB...)?
Regards
Jon Bowers
NI UK & Ireland
(3,321 Views)
Hi Jon,
I am using LabVIEW 8.20, and a PCI-6115 DAQ board.
Tom
(3,315 Views)
Hi Tom,
If you are using LabVIEW then you should be able to use the trigger property node to set the delay time. See the attached screen shot.
Regards
Jon B
NI UK & Ireland
(3,310 Views)
Excellent, thank you.
(3,286 Views)
