Syncronize a 4461 and 6601
@Kevin
Thats pretty much what I am doing now actually. Except I am doing it with the Quad Decoding of 8192 pulses. All the processing is done via software and the Encoder sampling is sync'd to the sample clock of the DSA.
I was looking for a hardware based solution so I can decouple my sampling loop from the speed monitoring. Since all timing signals are available in hardware, why not use hardware control? In my original post, I mentioned that I have a complete working system. I am looking to improve on the design by eliminating software processing of the signals. By doing this, the timing is embeded in the sampling interval and data can be normalized. I believe this will yield a more accurate and repeatable result for the process due to flucuations in the closed loop motor control.
Message 11 of 13
(808 Views)
Based on Katie's info, parts of my suggestion definitely won't work.  If the DSA can export a sample clock signal, other parts of the idea might still work.
Modifications would be:
- use the DSA sample clock to capture encoder samples
- configure the encoder for X4 for better position resolution.  Continue to reset to 0 on Z-index.
- you'll almost definitely be interpolating to find the 0-position crossings because the DSA sample isn't likely to coincide with the z-index
-Kevin P
Message 12 of 13
(807 Views)
@Kevin
Yep thats exactly correct. 0-position crossings have to be interpolated.
Message 13 of 13
(804 Views)
