System crash during DAQ operation
I sadly find that my windows XP system crashes wierdly when running the PCI-6221 DAQ card. And I'm posting to see have anyone been faced with the same trouble or know what's wrong with my card and computer.
Here is several points to make the situation clearer:
1.PCI-6014 works fine on the same computer
2.The 6221 works fine on another computer
3.Different slots on the computer also make differences. When the card is inserted into slot A, the system crashes at starting-up, while when inserted into slot B the installation is fine but the system still crashes immediately or soon after the labview program is launched.
Thank you so much!
(3,034 Views)
since the 6221 works fine on another PC, so can you reinstall your XP system?
I think there may be something wrong with the OS.
If it still doesnt work, you should check whether the PC hardware has sth wrong or not
(3,019 Views)
