System won't boot with PCI-6014 installed
I am using multiple PCI-6014 boards in several systems. One of the systems now fails to boot. By trial and error with parts from other sytems, I have determined that I have a PCI-6014 board which if I place it in any system, the system it is in will not boot. If I remove this particular PCI-6014 board, then the system will boot. These same systems will boot and operate properly with any of my other PCI-6014 boards installed as well.
(2,760 Views)
It appears that there is a problem with the board that prevents the systems from booting up. If you have tried the board in different slots and different machines with the same results, the next step is to request an RMA (Return Merchandise Authorization) for that board by calling our customer service number: 1-866-275-6964.
-Alan A.
(2,731 Views)
