TB 4300, Connected to PXIe 4300, Measurement issues
Hi all,
I am trying to measure voltages using the cards mentioned above. This card has 8 channels and I am connecting them to a battery pack all connected in series. The issue I am having is that the first and last channels, channel 0 and 7 are reading low (approx 2V whereas they should be measuring 4.05 V). The other channels are all reading properly. I am sure that this must be a grounding issue but after many attempts of re configuring the grounding cables in different ways, the results are the same.
When using only 4 channels, ie channel 0 to 3, everything measure properly, it is only when I have all 8 channels attached that problems occur.
Any help is appreciated.
(2,817 Views)
Do you have any other way of measuring the actual signals being sent to the card? I'm wondering if the battery pack has enough power to supply for the 8 channels? I'm not sure why that would make channel 0 and 7 low though, it seems kind of random. How do you have the grounds hooked up currently?
-Ryan
(2,742 Views)
