TTL NI 9401 Edge counting work but not frequency measurement
Hi everyone,
I have a CompactDAQ and a NI9401. I used this hardware with labview to monitor the speed of a crankshaft. My sensor (optics) output a square wave, 0-5v amplitude, TTL compatible.
I have check it on an oscilloscope, it is perfectly well tooth shaped.
 I connect to 9401, and I try these 2 simple .VI in attachement and weirdely,
the edge counting work perfectly, (and the increment speed correspond to the speed of the crankshaft)
But, frequency meserment or pulse with, or period, do not work
Does anybody has a idea why ?
(I struggled during 4 hours and I didn't figure it out)
thank you very much for you help,
Guillaume.
Message 1 of 8
(5,617 Views)
Have you spent any of that time looking at the specifications? It has no counter so I don't understand how even the first example works.
Message 2 of 8
(5,611 Views)
It uses the counter of the cDAQ (it has four counter !)
Message 3 of 8
(5,608 Views)
Sorry, did not know that about the cDAQ.
Have you run the example called Meas Dig Frequency-Low Freq 1 Ctr? I am not that familiar with cDAQ but you should check to see if the default source connections for frequency are the same as for counting edges.
Message 4 of 8
(5,605 Views)
thank you very much for your answer,
I'm not able to check if the example vi works until tomorow unfortunately,
but I'm quite pessimistic...
Guillaume.
Message 5 of 8
(5,577 Views)
Accepted by topic author gdlbb
Hey, I found my problem,
I need to plug the wire into line 5 instead of 4
I choose ctr1 for instance, and then edge counting work ONLY on number 4 and frequency, period measuremnt etc work only on line 5.
tricky for me.
greets,
Guillaume.
Message 6 of 8
(5,539 Views)
Which is why I mentioned that you should check the default source connections. The source connections are something you can change.
Message 7 of 8
(5,536 Views)
Indeed, I will try to do that to be able to genreate 3 pwm on 3 different lines, not at the same time, using the same counter.
I found this example, and I will try to run/adapt it on my CompactDAQ : http://zone.ni.com/devzone/cda/epd/p/id/4422.
thanks,
Guillaume.
Message 8 of 8
(5,531 Views)
