TTL displacement sensor connection to PCI-1200
I am trying to insall a TTL displacement sensor to the equipment
PCI-1200 DAQ and connection interface BNC-2081
I have tried connecting it as a digital input application to the 22 PB0 of
my PCI-1200 but then I have yet to obtain a signal in my hardware
configuration manager.
I have also tried connecting it as a counter to the 45 CLKB1 of my
PCI-1200... and I get a signal but I am not sure where to go from there.
Which approach is correct? Which VIs can I use to count the TTL pulses?
colin sanctuary
¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø¤º°`°º
Colin Sanctuary
DGM ICAP LMAF
CH-1015 Lausanne
Tel Bureau: +41 21 693 7379
Tel Lab: +41 21 693 5155
Fax: +41 21 693 350
9
(2,682 Views)
There are daq counter examples for LabVIEW that demonstrate how to count rising-edges of TTL pulses. You can access the examples through the help menu in LabVIEW. For the PCI-1200 you will want to view the data acquistion counter examples for 8253-based devices. Check out the Event Counting example.
Raecine Meza
http://www.ni.com/ask
(2,682 Views)
