TTL on multiple channels on LabPC+
Hi!
I have to generate timed TTL pulses on multiple channels (at least 2) on
LabPC+ DAQ boards in the same time or delayed.
Is there any possibility to have timed digital output on the DIO lines of
the 8255 if possible with internat clock?
(to set the pulse widths and pulse delays using LabVIEW VIs?
Or I should use the timer 8253 output for pulse generation but how can I
obtain pulses on more channels?
I appreciate any help,
Barna
Message 1 of 1
(3,432 Views)
