TTL signal
Hi:
Can PCI 6250 broad measure digital current, such as TTL signal (digital current)?
TTL is a signal which go either high or low.
I am very sure. Can you answer to me directly?
(3,025 Views)
How many times are you going to ask the same question? How many times have you gotten the same answer? One last time. The 6250 measures voltage. You calculate current by taking a voltage measurement across a known resistor. The 6250 can easily measure a digital voltage.
Before you post again, I hope you can come up with something a bit different. You seem stuck on the most basic principles.
(3,017 Views)
