Take readings of Vibrating Wire Gage
I am trying to read the strain from a vibrating wire gage. Is that possible to use a NI LVDT card to acquire the data?
Thank you so much.
(3,563 Views)
what type of strain sensoric do want to use?
classical resitive strain gauge bridge?
charge based piezo sensor?
laser ?
or ?
Greetings from Germany
Henrik
LV since v3.1
(3,541 Views)
It was a GEOKON vibrating wire gage which basically measures the frequency of a string and convert it into strain.
Greetings from Chinese in US...
(3,531 Views)
So the information is the frequency.
Well, depending on the frequncy range you can use analog input (maybe even a soundcard) or a timer/counter input.
If you use an anlog input you can use the the 'extract single tone vi' to detect the major frequency...
What type of exitation or power supply is needed?
Henrik
LV since v3.1
(3,521 Views)
