Technical documentation
I am looking for the NI documentation (from where I can study) on the following topics:
1. RTSI Bus
2. Handshaking
3. PFI lines
Thanks a lot
(2,725 Views)
Most of the documentation on the RTSI bus deals with specific applications which utilize RTSI. If you have a specific application it will be much easier to find documentation. The RTSI bus provides the pathways for signal routing, more documentation on its configuration can be found here as well as its pin out. With regard to handshaking, I suggest the Digital I/O Applications Developer Zone document. PFI lines vary slightly depending on the series device that you have the linked document explains the operation in each. I hope this helps!
JaceD
Signal Sources Product Support Engineer
(2,701 Views)
