02-25-2008 02:33 PM
02-26-2008 11:39 AM
02-26-2008 01:29 PM
John,
Thanks for the reply. Our thermocouple measurements are made in differential mode. This morning I changed voltage sources (similar model) to one which had a working battery. Changing to battery mode made a huge difference in the signal noise. I am also using a multimeter (which is AC powered) to confirm the voltage signal. On the advice of our instrumentation staff, I also tried measuring the thermocouple signal with the multimeter removed. Although the average temperature readings did not change, the standard deviation of the readings was greatly reduced. The reading are now acceptable for our verfication purposes.
I will also follow up with reading the document you suggested.
Cindy
