Temperature/Voltage Measurement Using NI 4350 and TBX-68T
Hello, this is my first time to use these device. I'm wondering if someone can help me give a sample code to work with NI 4350 / TBX-68T. I tried to use the NI Example Finder but no luck.
Thanks in advance.
______________
KowdTek
LabVIEW 2009
One Step At A Time, Maybe Two...
(2,936 Views)
Hi FlipTek,
The NI 4350 is a device that is only supported under the traditional DAQ driver, so there’s not a lot of newer material out there. But if you visit ni.com/devzone and look in the “Browse” section, you’ll see that you can search for “4350” and narrow it to examples, etc. By doing so, I was able to find 5 examples here.
You may also want to look at the other resources available at ni.com/support. Although there is no specific support page for the 4350, you may use any of the resources linked here, such as the product manuals, KnowledgeBases, Drivers & Updates, etc.
I hope that gets your started.
Mark E.
Precision DC Product Support Engineer
(2,911 Views)
Thank you very much!
______________
KowdTek
LabVIEW 2009
(2,905 Views)
