Temperature and Humidity Monitoring on USB-6001 with LabView
I just started working on a project where it is required to monitor the temperature and humidity in real time using a USB-6001 DAQ. Before I came into the project, they were attempting to use the CC2D25-SIP sensor that communicated using I2C protocol which to my limited knowledge is not possible with the USB-6001 due to the need for a min 20kHz clock output to the device. I was wondering what sensors (analog or digital) that people would suggest using for such a task. We are going to be implementing this project using LabView. Forgive my general ignorance, naturally I would have attempted this with an arduino but unfortunately I am in a position more or less obliged to use the USB-6001 which has been purchased specifically for this task.
Message 1 of 1
(2,522 Views)
