Temperature measurement with NI9237 Bridge Module
Anyone with successful experience gathering temperature data using a slot in a 9237?
I have an application for full bridge measurements and would like to leverage an empty slot to capture temperature readings instead of needing a separate module.
I imagine I should be able to do it using an RTD and a completion resistor? Any guidance on wiring and LabVIEW configs for successfully doing it would be appreciated.
Plan to bench test this soon but wanted to see if others had experience to share to get me a head start.
Thanks in advance,
Message 1 of 1
(268 Views)
