Temperature sensor with DAQ
Perform a VI where the signal of a variable of an industrial process (Lm35) is acquired, which gradually increases until reaching the value of 100 in a span of 20s. From here and after 10s the variable adjusts to a double value, after another 10s it doubles again and within another 10s it is reduced by half. A "Process Started" LED should light up throughout the process. You can stop the process at any time in the stop button.
(2,878 Views)
What is the question?
I can recommend you to use a state machine on LabVIEW.
https://www.ni.com/en/support/documentation/supplemental/16/simple-state-machine-template-documentat...
Have a nice day!
(2,842 Views)
Have you use some LabVIEW example?
(2,819 Views)
