Temperature values vary using usb-9211
I am using a USB-9211 to record 3 temperatures that are all connected to a waterbath that is set at 21C.  The recorded temps vary over time more than a degree or 2 each way with no apparent pattern.  There doesn't seem to be any reason for this. The water bath is calibrated and is accurate to +-.01C.  I tried using an ice bath with the same results. Do you have any idea what could be causing this variation?
(2,674 Views)
It appears this thread has already been replied to. Click here: http://forums.ni.com/ni/board/message?board.id=170&message.id=215621
Elijah Kerry
NI Director, Software Community
(2,655 Views)
