Test Panel in VI format
I am looking for the Measurement & Automation Explorer (MAX) Test Panel in a VI format. It has the ability to write or read from all lines in the DAQ. Each line is modeled as an LED.
I know that the test panel is available in the nitpan32.exe. I need to make some slight modifications to the file and was looking for it in VI format.
(2,767 Views)
Greetings,
I am not aware of the existence of the Test Panel as a VI, but the example "Dig Multi-line Direction (E).vi" does accomplish what you have described. You can assign each line's direction, and they are represented by an LED (input) and a switch (output). This example is installed with LabVIEW.
Good luck with your application.
Spencer S.
(2,767 Views)
