The ability to measure temperature with the USB 6008?
Thanks for your reply!
The problem is that the sensor is not responding to any change in heat/temperature. I'm not sure what is wrong =( It could be the programming.
But can you tell from the pictures if the connections are right between the sensor and the DAQ?
I will check my connections ones again and come back with the results.
Best regards
/Mattias
Message 11 of 18
(2,051 Views)
Do you have a simple voltmeter and a voltage source  to do a test without the 6008?
Greetings from Germany
Henrik
LV since v3.1
Message 12 of 18
(2,046 Views)
Yes, I have access to a voltmeter. I have also checked the analog ports on my DAQ with a standard 9 v battery so I do not think these are broken.
But I think I start by checking with a voltmeter if anything happens when I change the temperature of the sensor.
Thanks for all of your advises!
Regards..
/Mattias
Message 13 of 18
(2,043 Views)
Looking at the spec sheet for the LM35 shows that you may need some additional circuitry if you want to use the 6008 to measure the output.  I've never used the LM35 but a quick google circuit search shows that most circuits seem to have the output terminal shunted to ground through a resistor.  This would probably be for reading with a DMM or other high impedance input.  That brings up another concern in that the 6008 input impedance is spec'd at 144 KOhms.  Not very high at all.  You may need to add a buffer of some kind like an op-amp voltage follower to the output of the LM35 and possibly the resistor to ground as well.  This would help eliminate the effects of the measurement circuit; either the 6008 or a DMM.
Tom
Message 14 of 18
(2,030 Views)
Hi Rockarmatte,
Currently I'm doing my project using thermocouple K and USB 6008. Why do you think it is impossible to use thermocouple K with 6008?
Thanks 🙂
Kind regards,
yugiha
Message 15 of 18
(1,660 Views)
Well, I haven't got it to work =( Have you? Please let me know... I think the resolution using 6008 is to bad with thermocouple. I connected the cables to the analoge input but it will not work.
Regards
Mattias
Message 16 of 18
(1,651 Views)
The 6008 is not a good choice to measure a thermocouple.  A K type thermocouple has a sensitivity of around 40uV/C.  The +/-1 V range on the 12 bit 6008 means that the sensitivity of the 6008 is about 490uV, and its accuracy is only 37.5mV.  In addition, to take a thermocouple reading, you must have the cold-junction temperature.  Unless you will put the junction in a bath at a known temperature, you will need to measure the temperature of the bath.
Message 17 of 18
(1,645 Views)
Hey,thanks for the info 🙂
so, If I want to use 6008 for temperature measurement from thermocouple K, I need to add AD 595 (as amplifier) and CJC?
that's all? Thanks before.
Yugiha
Message 18 of 18
(1,633 Views)
