The input arrays do not contain the correct number of data values for this functin
I got the data from the DataSocket ant want to plot the wave and its spectrum,but i got Error Message:
Private Sub CWDataSocket1_OnDataUpdated(ByVal Data As CWData)
'When an update is received OnDataUpdated is fired.
Dim AmpSpectrum As Variant
Dim PhaseSpectrum As Variant
Dim dt As Variant ' amount of time per sample
Dim df As Variant ' df will be the frequency
Dim ptsPerScr As Integer
Dim scanRate As Integer
Dim chNum As Integer
scanRate = Data.GetAttribute("scanRate", 10000).Value
dt = 1 / scanRate
I
f (IsArray(Data.Value)) Then
CWGraph1.PlotY Data.Value
'plot the spectrum
CWDSP1.AmpPhaseSpectrum Data.Value, 1, dt, AmpSpectrum, PhaseSpectrum, df
CWGraph2.PlotY AmpSpectrum, 0, df
ElseIf (IsNumeric(Data.Value)) Then
CWGraph1.ChartY Data.Value
End If
End Sub
(2,920 Views)
Hello
Which function is returning this error? Is it the ploty or the ampphasespectrum function?you might want to double check and see if you have all the data that you want to analyse and whether the analysis function is returning the adequate number of points. If you think this has to do with the number of points, try using a dummy array that is the same size as the datasocket array you are sending and see if that causes the same problem.
Bilal Durrani
NI
Bilal Durrani
NI
(2,920 Views)
AmpPhaseSpectrum ,this function cause this error.
i write data to datasocket by using the following sentences
hr = DS_SetAttrValue (dsHandle, "ptsPerScr", CAVT_LONG, &ptsPerScr, 0, 0);
hr = DS_SetAttrValue (dsHandle, "scanRate", CAVT_LONG, &tpTyroProject->Acq.AcqRate, 0, 0);
hr = DS_SetAttrValue (dsHandle, "chNum", CAVT_LONG, &tpTyroProject->EnabledChNum, 0, 0);
hr = DS_SetDataValue (dsHandle, CAVT_DOUBLE|CAVT_ARRAY,data ,
tpTyroProject->EnabledChNum,ptsPerScr );
(2,920 Views)
