Thermocouple noise/inaccuracy and effects of setting sampling rate on USB-6259
I am having several problems with my USB-6259.  First, it is not accurately reading my thermocouples.  I have K-type thermocouples connected to it, grouped together and scanning one after the other.  I set my range to -100 mV to 100 mV, as they dont go above 50 mV.  The data is very noisy (the thermocouples are grounded), and one of them is reading 55 mV.  When I use a multimeter to probe the screw terminals on the board, it shows a more accurate 19 mV.  For some reason this voltage is not being read by my system.  I have no idea what to do.  I am using a USB 1.1 port, not a 2.0, so would this have any effect?
One thing I did to try to remedy this was to set up just those 3 thermocouples in a separate program (I have pumps, compressors, other 0-5V signals coming in along with the thermocouples in my first program).  When I set the sampling rate to 250kHz, and the number of samples to 8000, it pretty much fixed everything and the numbers were great.  Two things:  1.  I thought that decreasing the sampling rate would help make it less noisy because of settling times, but this is not the case in practice, and 2.  with my full program, I can't run it that fast, so that solution didn't help me.
Does anyone have any idea how to get my program to work and display all of my data correctly.  I am going to be using the PID control toolkit for cooling, based on the temperature data I read from this unit, but that wont work if my temperatures aren't steady, or correct.
Thanks in advance!
(3,240 Views)
Hi topaz,
Are you also getting these incorrect measurements in Measurement and Automation Exploerer (MAX)?  If so, do you have the correct thermocouple type selected in your task?  The default type is J so if you don't specifically select the K thermocouple type, you could get inaccurate measurements.  If you think increasing the sampling rate corrects the problem, try increasing the sampling rate in MAX to see where the problem goes away.  It's always a good idea to start troubleshooting hardware problems in MAX so we can determine if the problem is in hardware or software.
Erik
Message Edited by Erik J on 01-10-2007 04:13 PM
(3,215 Views)
