Thermocouple
I'm new to temperature measurement using thermocouples.
I want to use the NI - 9214 which supports different types of thermocouples. My questions is: How does the module know, which type of thermocouple is connected?
Kind regards
Kolja
(2,870 Views)
Hi Kolja,
You tell it what the thermocouple type is by passing a parameter to the DAQmx Create Channel VI or by selecting the type in the DAQ Assistant.
Brad
Brad Keryan
NI R&D
(2,854 Views)
I am using SCB-68 M Series device and PCIe- 6363 to acquire data from thermocouple using labview signal express 2010 version 4 at a range of 400-800 degree centigrade using K type thermocouple.but not able to get the data
what will be the cofiguration setting to use in differential mode?
Thanks & Regards
Avik
(2,838 Views)
